So I finally got around to installing the anti-ratchet drivers on my SRX. Problem is how far do the drivers go from each end of the axle? Somebody has to know other then the Yamaha shop. Thanks
i dont understand what your saying.the drivers should have ( teeth) on both sides and around the diameter of sprocket also.there are timing mark arrows on sprockets that you need to have lined up.i guess i should asked what brand you have.
I think you need to run your stock or same size external driver.
I just installed some Wahl extroverts, they have the drive cogs on both sides.
I got my Wahls from Hartman. I think they were about 150.
Someone here may have a better price.
These are the same ones that on my 99 Mtn Max. I have no trouble with them. Besides the used track I bought the inner cogs that the stock drives run on are tore up so I have to go with anti ratchets.
