STILLCRAZY
New member first post.
Just signed up last week and was able to clean my carbs (first for me) thanks to the awsome instructions from this sight. Also did the reed stopper notch and my '00 700 SX-r runs like new.
Now onto clutching which i know nothing about. 5000 miles and nothing has been done to the clutches. Engagement is good but tops at about 9000 RPM.
Whay should the RPM be ? What is probably worn out ?
I will check for replys after Christmas. Thanks !!
SC
SC
Yama49601
STILLCRAZY
Wow ! that was fast. Is that easy to replace ?
Thanks Yama49601
SC
Thanks Yama49601
SC
tedgoesfast
you want it to go to 8000 then swep tach to 8300 they had some problems stock at overrev check turks set up in tech pages i put a pin kit to use a52 cat weights geared top gear to 22 53-46 helix it flies stock springs the only problem it engages low 3300 but i trail drive so its not a issue
moss
Not very hard, but you would need a primary Clutch puller....STILLCRAZY said:Wow ! that was fast. Is that easy to replace ?
Thanks Yama49601
SC
shortstop20
- Mar 6, 2005
- Stickney, South Dakota
- www.snowmobilefanatics.net
You can do it without a clutch puller but it's a pain in the butt to change that stuff while it's still on the sled IMO.
Yama49601
I've never pulled my clutch and I've changed springs and weights several times. I'm sure it would be easier with it off but I don't have a problem with it on.
STILLCRAZY
Thanks Everyone ! I will get the clutching in order this week.
