I have a '93 Exciter II with a 570 win. I recently took the carbs apart to clean them but, I didn't trust the settings of the air/pilot screws or the idle screw setting because of the joker that owned the sled prior to me.
The tech info on the belt guard says that the air/pilot screw should be turned out 5/8 of a turn. These carbs are a round slide with a electro-mechanical solenoid on them next to the air/pilot screws. Is this setting correct? How about setting the idle screw prior to starting it? The setting before I tore them apart was 3 turns out but, the carbs were pretty dirty and I think the previous owner had been in screwing around with things instead of taking the carbs off to clean them.
Is there an easy way to get the carbs out/in?!?!?! Man, I had to remove the intake boots after taking the air box loose just to get them back in easily.
Mills
Mills
tedgoesfast
my 93 exciter is the sx version has flatslide carbs i have to remove the rubber between the air box and carb also i remove the 2 10mm bolts under the little plastic cover this allows the air box to go back a little flatslids are on a rack they come out together
