Hello all, great forum. My wifes 700 Venture has a wicked clunking noise coming from the front of the drive train / track. I thought the drive chain skipped or sprocket chipped a tooth. Opened her up last night, everything in chain drive case appears fine.
Put track up off ground and ran it and clunk was not present? Only when weight off machine is on track does it make the clunk, happens both in reverse and forward, every revoultion of track. Checked track for a rock or something stuck in slide nothing.
I have had suggestions that it could be the secondary shaft bearing or as simple as the track being to loose, could the it be as simple as the track being loose ?
Thanks all,
Thanks all,
