racer21
I ran my 1997 500 in 1000' today and after a few clutching adjustments it did 91 mph, does anyone know of a decent speed it should run or am I close to as fast as it should go?
bufalobob
that's good if it's a 500cc full bodied trail stock machine. click on the link below. they don't list a 500cc class but the record in 600 is 98 mph.
how did you record the speed?
http://cmsaracing.com/records.htm
bob
bob
racer21
We measured out 1000' on ice track, we used a radar gun and ran 5 times, all were at 91-92mph, It is a full bodied stock sled, we just did some clutching changes and suspension adjustments, next weekend we are going to shoot for 95-100 mph, we are going to get serious about it this time.
yamyrider
wow that is good speed for a 500 in 1000ft. What did you do the the suspension and clutch.
bufalobob
i see by your post you are from min.. go to a cmsa event & let us know your results!
bob
bob
racer21
I don't think I can be competitive with those guy's.
woolyviper
I get a 403 error when i try to click on the link - website must be down.bufalobob said:
bufalobob
wolly:
just clicked on it & works for me??
racer:
the only way to find out is go & race. 91-92 mph in trail stock will be right up front if not 1st.
bob
racer:
bob
racer21
I am going to see how we do this weekend testing, I will update as we go. R.J.
Bushman
racer21 said:I am going to see how we do this weekend testing, I will update as we go. R.J.
Is this on snow or ice? The reason I ask is two years ago I went to a 500' snow drag here in northern Michigan, Before they ran the drags they had a radar gun set up on another 500' snow track. For $20.00 we got to make 3 runs. First run was with my drag setup & crap, It was a slow mph vers some that ran. So against my better judgment I tightened my secondary to 70 twist & second run I picked up something like 7-8 mph. Figure to myself I was on to something so I tightened my secondary to 120 with the Yami Silver spring & ran close to 12-14 mph faster than my first run. Now I was feeling much better about myself & my tuning ability so I figured I would run the first round with the tight secondary & mph them on the big end. Guess what? In 500' there is no big end & got stomped bad. So now if its drag I run my secondary as loose as possible because it's all about the upshift & 800'+ solo speed run I tighten that secondary as tight as I can get it holding the clutches back getting it to mph. Speed run vers other sleds is more like a trail setup because quick is needed along with mph to keep ahead & depending on snow condition which is huge I'll run 60 twist.
Give it a try & you too can pickup some big mph on the gun....... Just dont try & drag race it setup like that
racer21
I had my secondary set at 110, 82mph was top speed, I then went down a lower number and gained, then changed helix and gained more, when I was drag racing I would keep the wrap tight for a hard launch out of the hole and it would also work the motor to it fullest to get the most hp to the ground, but, every sled is different.
Bushman
racer21 said:I had my secondary set at 110, 82mph was top speed, I then went down a lower number and gained, then changed helix and gained more, when I was drag racing I would keep the wrap tight for a hard launch out of the hole and it would also work the motor to it fullest to get the most hp to the ground, but, every sled is different.
I should have mentioned I was running a Hauck Roller also & there alone could be the different settings. Have fun with it because that is what matters most
tedgoesfast
my exciter sx went 96 mph on ice in a thousand feet i hope try my sx 700 this year
woolyviper
anyone else having trouble with the link?bufalobob said:that's good if it's a 500cc full bodied trail stock machine. click on the link below. they don't list a 500cc class but the record in 600 is 98 mph.
bob
i tried it on two diff computers and even my blackberry and i get a 403 denied error.
tedgoesfast
no i can get right on
