cjkusmierz
thanks guys. i will keep you updated. Once we get some snow here i will take a closer look at the RPMS and Spedo gage and i wil ride next to someone who has a digital gage.
braindead1684
You mentioned you replaced the rollers and such on the primary, did you make sure everythings is back together correctly and nothing is loose. Check the alignment as a fresh clutch may show up problems that where not visable with a worn out one. Also look at the secondary, that sled should hit 100 Easy, Was doing 80 in a foot without pinning it on my xt So you shouldn't have a problem either.
