Stroketech
I have heard certain old Exciter engines refered to as a 433 "SS". What is the difference and what years or models had it?
Thanks, Jon
			Thanks, Jon
dws743
Ss433
The SS433 motor was used in all Exciter 440's and was made from 1976-81. It had reed induction & CDI and was rated @ 48 HP. There were some changes made over the years-the cylinders and clutch were changed after '76; the carb was changed after '77 and the cdi boxes were changed a few times.
They made another reed induction 433 called the S433 which was used in the '74-'77 GP433/440. This motor had points & condenser ignition and was rated @ 40 HP. It had the old style clutch although it had aluminum sheaves.
Sno-Jet also used the SS433 in the 1976-77 SST.
							Stroketech
Thank you.
Its just that you see 9 exciters and then the 10th one the owner says it is a 440 SS like its special. Now I know. Thanks.
Jon
Jon
