troyhatt
has anyone put the rx1 2003 rear drop brackets to gain height in the rear of a srx? The axle needs to be shorter. will the axle of the rx1 2003 fit the 2001 srx? each sled has the same part# but different prefixes. i am assuming one is different? any thoughts? thanks...
if you want to use the drop brackets you will need to cut about 1/2in off each side of your shaft or find a shaft from a rx1 or a venture
