How do I make the sled shift out higher? I have a comet primary and stock secondary. if I remember right I need more pretension in the secondary spring. There are not many springs available for this will other springs work. Or am I going at this the wrong way. I have purple spring -758 in the primary with n1 notched wieghts. It engages at 5500 but it seems to shift out to low. I'm hitting 9000-9200 top rpms. Should I throw more wieght at it? The belt seems to slip at top end also. Any suggestion are welcome. Thanks in advance.
