Yamanewf
If you have too much transfer will your sled ride worse on a rough trail?
tedgoesfast
i have mine to the max and it rides better but also i have the bender rods that you can adjust coupling
Yamanewf
Do you mean that you have the rods set at max and it rides better?
151Viper
This is the way I understand it. I could be wrong though.
less transfer = better trail manners but a stiffer ride
more transfer = rougher ride on the trail due to less coupling action and a softer ride
Yamanewf
That was my take on it as well. I just wanted someone to confirm it and/ or explain it.
think of it as the shocks work together, when the control rod gaps are closer the shocks work together as a unit quicker, when the gap is larger they will work more independantly of each other longer before they couple and work together.....CP
