89 exciter, what are the bennifits of using a newer vmax secondary? i'm either planning on using the vmax secondary or tuning the stock secondary to SX specs... thoughts?
tedgoesfast
what rear spring and helix are in it now
not sure what helix it has, i beleive the helix itself was the same between the SX and other exciter models. my secondary has the white spring, SX models had the pink spring. they both used the A-2 setting from the factory.
tedgoesfast
sx has pink spring with 39 degree helix
94 vmax came with pink secondary stock, and they have the helix on the outside, so overall it sounds like a better clutch anyways. anyone know if it will bolt right on an EX570?
Classic SRX
You'll need a longer bolt and a spacer to bolt it to the jackshaft. I read somewhere that one from an SRX (probably all the triples) will work. Haven't done it myself yet.
A.
A.
