mm700sleder
what would you pay for a 2000 sx500 with 4000 miles, in half way decent shape. not perfect but fairly clean. doesn't have reverse or electric start.
Not a wole lot, $1000-$1200 if it's clean...should have rings put in.
mm700sleder
its off a fresh rebuild. i worked him down to 1200. should i jump the gun
If it's a fresh rebuild with OEM parts and clean(any damage?) i'd probably
pull the trigger yes..
all stock run good???
mm700sleder
no damage. a couple of scraches of the trailing arms, and the track is a little worn but definatly usable for another season or two
I'd jump on it. That slead around here would be 2500.00.
Pull the trigger!!!!
