My sx 700 backfire and fouls out
betterbadguy
Michgan
Ok first of all i cleaned my carbs set the to spec. put them back on... right well it was backfiring and when it did u could see it pop out smoke by the center of the head towards carbs.. anyways it also fouls out main plug barely a little black on the others. also the compression check was 125 all the way across so what could this be going to try to flip plug wires around maybe i have a bad coil but i would like some advice here not so good on workin in them first year of having problems
It really dose sound electrical. but i never touched the float. where do i find a cheap tool to measure it at. but sometimes when u messed with a wire it would pop... sound better then go back to poping now it dont matter you give it gas and it barely wants to move and pops and backfires. total loss of power
also fouled old plug i bought new plugs and im going to check the coils the headlight and if any other ideas like to know new to workin on sleds thanx guys
I think when i took off the carbs i didn't get them back on tell three days later got moisture in the cylinders or something. but i always had the tors disablabled. but shes back up to goin fast thanx alot thou guys might have problems later.
