Phazer help wont run
phazer carbs
It sounds like a hanging up choke . If float hieght is way off it will spill out into engine , usually that cylinder won't run except wot . You must get a synk gague , drill bits not precise enough . Synk gague compensates for diffrent vacumn pressures in cylinders . Set those choke cables like 8VO told you . Recheck those rubber plugs . No idle screw setting will dump that much raw fuel out exhaust .
