can a 1.25" ripsaw be studed on 01 srx?
The purpose of the radiator(heat exchanger) protectors, is to protect it from stud damage. Never run studs without them!
Also, most people will tell you , you have to change your front drivers to 8 tooth instead of the 9 tooth that is stock on the sled. This allows you enough room to put the protectors back in with a 1 1/4" track.
I have 1 1/4 predator track studded on my 2000 srx, stock nine tooth drive. Bought the sled used with the track on it. Had to cut 1/4 inch slots in the lugs so that they would not rub on the protectors. Works fine now. More snow please.
