hi a was wondering if anybody knows if a 1.25 ripsaw track will go on my 93 exciter ST please let me know thanks
Without switching my drivers i mean....
nightmanx1
I have a 1.25 on mine with 9 tooth drives, it is a b@tch to get it in but you should have 1/2 in clearance at the front heat exchanger when all done.
tedgoesfast
my 1993 sx i put a 1 inch track with 1.25 studs and it clears fine the sx does not have a front heat exchanger
curious does the SX use anything in place of the heat exchanger? IE an additional on elsewhere? or a surge tank or something? i'd like to ditch the front exchanger on my 89 if possible. BTW I have a 1" with 1.25 studs and it clears the front heat exhanger with about 3/4" to spare... but i also have 8 tooth wahl bros drivers
seca
thats odd, the sx i had did have a front heat exchanger.
ace16a
Without checking, I pretty sure mine has the front exchanger too.
