2000 SRX: Possible Electrical Problem
jaydaniels
Amherst NS
Well, I just bought a 2000 SRX and it seems to run fine and is in great shape. I did have one problem though. Tonight , when I first started it nothing electrical worked at all. No lights, tach gauges or hadwarmers. However, the motor ran fine. Anyone have some idea of what this could be. I asked the guy before I bought it if he took care of the wiring issue under the motor and he said yes. I looked and it does have the plastic covering which I don't believe comes on them stock. After my sled idled for about 5 minutes everything came on and worked fine.
load control relay, light relay, they probally just need dried out on a heat register in the house, these are the white and blue relays on left hand side footwell, take em in the house and put em on heat register, will be fine
Great, thanks. I hope that is the problem. Sounds like an easy fix.
