bar risers/ elec. extensions?
DMACK
Fowlerville,Mi
I am going with a 6 in. riser, my ? is how do I extend the electrical wires?
I got the throttle and brake cables with the kit. haven't seen any extensions for P-brake or elec. any advice would be appreciated.
extensions
Thanks,Yamiman I was afraid that would be the case.
I was hoping for some kind of plug and play extension.
and removing the brake is no big deal (never used it)
When extending the wiring don't use butt connectors. Take the extra time and solder the wires together. Butt connectors will get moisture in them and corrode. They also can expand and contract with cold temps. Just a little corrosion can make the difference between starting or not. Not a good thing 50 miles from the truck. Solder and shrink wrap each wire. Does take more time, but could save major problems on the trail
Later
