gbic1
OK I have read the threads and every one say it dont work. Some thing about Clevis type mounts. I have a pair of shocks here that I was told were off a RX! (new) and they have eyelets top and bottom. With out removing the stock Ohlins they seam the same. Are they too long to fit? I got this picture off ebay. The shock are identical to this.
http://cgi.ebay.com/ebaymotors/Yama...198059685QQcmdZViewItem?hash=item140198059685
Your stock ohlins shocks are about 13.5 inchs long (eyelet to eyelet). You need to confirm the length of the RX1 shock. With a stock width front end I would guess they would be too long to fit. Whats wrong with your Ohlins shocks?
gbic1
18.5 end to end. I and just trying to lift front a bit. Ohlins are fine as far as I know.
you will bend rad rods and trailing arms with that long of a shock on stock trailing arms. It makes the bump steer stupid on it. Maxdlx
gbic1
Thanks, tghat was the answer I was looking for. I guess I will get the shock extensions.
I put shock extensions on my ohlins shocks. 5/8" rod extensions from Advant-edge Motorsports. This gives you about 1 inch more ski travel. Have run these for a few years now with no troubles.
gbic1
I have been googleing looking for these extenders. Anyone have part number and good place to purchase? Also looking for best deal on 8 in carbides.
