power valve tester
nighttrain9
EAST CHINA michigan
How does the power valve tester work? When I apply power the servo motor opens 100% But when you take power off it turns back 1/4 turn . Do you have to leave the power on all the time while doing this to get your 2.5mm gap? If so is it hard on anything if you do.Thanks for the help NIGHTTRAIN9
No, the servo should stay put when key off or power off, if it's pulling
back the servo, cables must be to little to tight.
does the servo sit there and jitter wile powered up?
IT JITTERS so I took the bender racing power valve adjustment tool and chucked IT! I think at least $29 went down the drain! I then did What every one here does and slowed engine below 900 and thet stayed full open where I marked them. I am never ever going to buy any thing until I check here first! you guys rock. THANK YOU! THANK YOU!
DON'T throw that adjustment tool out(send it to me :) ) it's not the problem,i use that(made my own) when i do 'em, the cables were
just to tight,it'll do the same thing(jitter) once the sled starts..if overly tight
if your trying to adjust your vales here's a procedure to help ya out.
DAMAN Thanks for the help ! After I adjusted the valves I hooked back up the bender valve tester and it works . You were right on they were way to tight . Just found the sled last summer 414 miles paid $3700 2002 srx the sled of my dreams! I have turks clutch kit in it with pioneer 51/43 helix. I Am heading to munising next sunday for 7 days can't wait to ride this thing I am in East China we will have to hook up would love to ride the new deckerville trail THANKS AGAIN NIGHTTRAIN9
Good to hear, sound like a beauty, always use premium gas, BR9ECS plugs and listen to your DCS if it flashes..
good luck!!!!
