940ken
I am curretly running Heel X on my secondary . In fresh snow it runs 8600, on hard pack or trail it will run 8900 8950 . I think i'd like to go back to a regular helix . What helix should i buy?
mod-it
Need to know what pipes your running for target rpm's.
940ken
Aaen pipes
what primary weights are you using?
940ken
Heelclickers long bolt 3 washers on heel 3.3 gram bolt in center.
something like a 48/38 would work well in a button clutch.
940ken
Excellent!! Going to get one!! what spring do you should I start with??
I would try the stock red secondary frst, around 80 degrees, you may need more twist if you have excellant traction, if you get up in the area of 100+ twist and need any more to control the shift then swap to a green secondary at 60.
940ken
Stopped by Micro Belmont this afternoon and bought a 50/38 . Hope this close enough? Will try it out tomorrow night, unless I hear differently. THANKS SO MUCH FOR YOUR INPUT!! KEN
Powder Trax
Try a Shockwave Secondary setup. Adjustable helix range of 16 degrees. Every rotation is 4 degrees. ou can even get a multi-angle setup also.
I run the straight run in my modded mnt viper...works great.
