The end of the triple pipes have a small gasket donut that goes into the exhaust can.How are these attached to the end of the exhaust pipe.I can loosen the bracket over it and slide that back and forth.I need to shorten or grind the length of one of them gaskets so that the exhaust pipe can move back a little in order to seal tight againt the big exhaust donut that sits on the exhaust header from the motor.How are they attached,tried pulling one out and it doesn't move.Is it a tight friction fit or have threads and unscrews from the exhaust pipe.Can you really just slice 1/8 to 3/16 off the end and grind down to a smooth taper to go back into can inlet.Just have the center pipe that seems to have to move back a tad in order to really sit tight up against the big exhaust donut.
