tyler66665
I just got an SRX 2001 and was wandering if I should attempt to clean the power valves myself. Anyone have instructions on how to do this?
I am new to these power valves and want to know what Pull through means?
Thanks!
Thanks!
blue missile
check the tech pages and or search in this forum
Marker
It's a simple job that can be done in no time at all. Should get yourself a manual first to make sure you put them back in properly. I use Red Stallion combustion chamber cleaner, spray them,let sit for short time and remove carbon deposits,clean them but do not use anything sharp as you may gouge them, you may have top spray them again if they are bad. You will have to remove the pipes as well to get at the third valve unless someone knows a trick to doing that .
try a search on power valves,tons of info....
daman can do them for you and he is fast.LOL HI DAMAN>>how ya doing.
good pal..how's the 8dn's working??
jmp2204
IN THE TECH SECTION on this site there is info on the how to.I have posted pictures of my p.v. and i think the thread is on pg 2 now .It shows one pv that has had the cable PULL THROUGH and one that hasn't. It's not a difficult job ,but like anything ,be patient and take your time .
