What kind of tranny fluid do you guys use in your chaincase?
I wouldnt use ATF in my case,but if you do use a full synthetic oil...
try a search on here about that,you'll get lots of reading..
YAMMIEGOD3:16
AMSOIL. 3:16 (yammie tony)
Concept Carbon
ive been running amsoil atf for 2 years and its awesome stuff
goody_700
I changed my chaincase oil last weekend in my SRX, used Amsoil 15-40 synthetic.
ANYTHING SYNTHETIC will work just fine!!!
A K MtnViper
4000 miles with ATF, no signs of wear.
I used to run the suv full synthetic tranny fluid. I switched back to amsoil chaincase oil, and saw the same top speed #'s. just a bit of info. Maxdlx
03 viper, 19000 km's on amsoil ATF & still going...yes...19k's
Do you have to change it every year?
It's cheap insurance...three times a season...is what I do...cheerschadman said:Do you have to change it every year?
A K MtnViper
I put on only 750 ish a year, so one time only.
rancidjo
theblues said:It's cheap insurance...three times a season...is what I do...cheers
I run ATF (whatever name brand is on sale) with no problems...and change mine 3 times a season....cheap and easy to do
SRX7
thats a waste of time. hell if tranny fluid protects our car's trannys for 3 yrs or what ever then I think it will protect a damn chain and gears for a season +.theblues said:It's cheap insurance...three times a season...is what I do...cheers
rancidjo
SRX7 said:thats a waste of time. hell if tranny fluid protects our car's trannys for 3 yrs or what ever then I think it will protect a damn chain and gears for a season +.
I like to go into the chaincase at least once at the begining of the season, then in the middle of the season, and sometimes before a big trip i will change the fluid.... plus it's nice to get any contaminants out even if you are not splitting the chaincase. That's my opinion
PhatboyC
But if you get contaminants it should get caught by the magnet on the plug. Then if you get to much on the magnet you have another problem and changing the oil wont help.
Dave M
Just drain out the oil.....put the hose from the grease gun in the dipstick hole....pump till full.
I have used atf for ever, at least 10 plus years. I change it out once a year, have yet, ever, to see a failure from using it, it will be just fine in there. Its cheap, provides more then enough protection, is high detergent, doesnt become like mollasas when cold and it WORKS!!!
SRX7
Bingo.......use it.mrviper700 said:doesnt become like mollasas when cold and it WORKS!!!
