Hey guys,
First off, I am a visual learner! Meaning pics would be best!
How can I tie down my srx for 660' drags?
Where can I chain the front, And the rear?
PICS<PICS<PICS<PICS<PICS???????
Nik!
Nik!
Roost 'Er
I woudlnt chain the rear man, you NEED transfer on this track.... trust me, if you chain the rear down itll jsut lay a strip across the starting line, its a very loose line and is deep so transfer will be key, also again you dont really even need to lower the front i left mine stock last year and didnt have any problems taking out lots of sleds, they sit pretty low to begin with
Ok then...... Since you've been there and done that I will take your word!
Mr Viper replied to a post a week or two ago dealing with the same question. Sounded like he had a pretty slick and easy way to set one up. Fire up the search engine and see if you can find it.
Roost 'Er
98700 said:Ok then...... Since you've been there and done that I will take your word!
Yeah just work on your rear suspension set-up when you get there, your running stock proaction right?... do you have adjustable transfer rods or no? Go early and then around 12 i think they start letting you test and tune for about a hour so it works out good lots of time to dial her in
