blueblood
I saw a recent post on a stator not being compatible( diff year, diff sys)
I recently put an 04 stator on a 02 viper. I assumed there would be no difference. It seems to be working fine. Is there reason for concern?
no, all the vipers are the same, 02-04 you will be just fine.
blueblood
Thanks for the quick reply mrviper.
trail viper
just curious, did the old stator test ok before you replaced it? mine looks and tests fine, still having issues.
blueblood
Trail, I never tested the old stator, when took the old one off there was quite a bit of built up dirt ,rust etc. also a spot was worn thru where the whip comes into the stator.
I got lucky and found a stator from an 04 viper on ebay for 70 bucks. thankfully when I put it in it cured all my problems. Huge difference, runs like a new sled
blueblood
I dont remember the specific post but there was a guy on here that had his stator initally test ok but he brought it into his shop for a more in depth testing session and found it was in fact bad. not sure on the specifics of the testing. Once I couldn't find any rub thru on the wire harness I just took a gamble on the stator. All my symptoms just seemed like I wasn't putting out enough power.
