quickone87
I was just recently looking into a new track for my 01 sxr 700 and ran across the 136 kit on tracks usa its currently on sale now and im starting to consider it i mainly do michigan rideing houghton lake area and trails should i drop the money on that or just stick to a 121 track ??? And what track ripsaw ice claw any suggestions ?????? what are all you ski pullin guroo's running
SWEDE
I have a ripsaw and extensions from Tracks Usa, but my tunnel extension kit is from Rich on here which is a Hartman kit.There(tracks usa) rail extensions are great, but there tunnel extension leaves alot to be desired.I highly recommend the 136" setup and will most likely not run a 121" again, I have a m-10 though so its a little different , but the benefits of more traction, stability and a better ride still apply.Rich motorsports is now making some nice rail extensions that look just like trcks usa's so that could be a one stop shop for you, he is a super guy to deal with plus he supports this site.That ice ripper would be a super trail track for you, but won't hookup on ice as good as studs though.If you want a better a better off trail track the predator or cobra would be somewhat better, but the ripsaw is very versatile I run them a couple times with no studs and am still quite pleased with how they do.
I used the tracks kit on my srx. (144") I actually liked the tunnel extension as it did not come predrilled for anything. I wanted to do something different than the stock look. I went with a Warrior rear heat exchanger as it provided alot more cooling ability and a round tube bumper as well as viper mountain hose covers.
jason
I am very pleasd with my tracks usa 136 kit, but the tunnel extention could have been better. No hoes drilled for the heat exchanger. I also had my track hot knifed due to it would rub on the heat exchanger protedtors. I have the 1.25 ripsaw. I would deffinately get it clutched- I had goodwin due a clutch set up for me and had red line cycle tune the motor and install v force reeds and I can keep pace with my buddies mach z triple. Also if anyone can tell me where to get hose covers I would appreciate it. Jason
yamaholic22
jason said:I am very pleasd with my tracks usa 136 kit, but the tunnel extention could have been better. No hoes drilled for the heat exchanger. I also had my track hot knifed due to it would rub on the heat exchanger protedtors. I have the 1.25 ripsaw. I would deffinately get it clutched- I had goodwin due a clutch set up for me and had red line cycle tune the motor and install v force reeds and I can keep pace with my buddies mach z triple. Also if anyone can tell me where to get hose covers I would appreciate it. Jason![]()
Order mountain viper hose covers from your yamaha dealer or check the classifieds on this site to see if anyone has a set for sale.
