Really Small Hands
What could help is loosen the throttle on twist it downward so its pointing more towards the gas tank............
S.X. said:
Good idea, but you are still pulling on your oil pump cable so in effect you are now runing oil rich with this scenario, that is why they tell you to set your throttle cable prior to setting your oil cable they must move in unison - with reason anyway.
I didn't think of that. Yes the oil pump cable will have to be reset also - unless it is a Phazer I or II which has the oil cable controlled by the throttle cable.
