chadincolo
I'm trying to get my son's Phazer (86) finished up to take to the mountains this weekend, had to replace the stator...get the stator, put it and flywheel in, put engine in, put pipes on...check and spark plugs are sparking good on the head. Prime with a little gas, nothing. Pull plugs and check for spark, good. Prime with a little carb cleaner, nothing. Ok, maybe weak coil, change coil, check spark, good, bright arc (new plugs). Prime with carb cleaner, nothing. Pull plugs, pull engine over to blow out cylinders, put plugs in nothing. Not making any sense why no reaction, no pop, no bang, no run...try a bit of starting fluid (hate doing that, too much potential for a big bang). Nothing... I have compression. I have spark when the plugs are out (can't really see into cylinder with plugs in, but assume they spark inside). I have fuel, be it gas, carb cleaner or either...not a pop, bang, backfire...what the heck is going on? Any ideas?
