I keep hearing a clunking when I Take off or come off a drift and land in allot of powder and have to pin it really hard.
Makes the clunking then I almost get stuck. Seems like my rpm's drop. Anyone know how to fix this?
I was thinking it was the track. But Im not too sure how tight I am supposed to run it.
Could be track ratcheting,when lifted in the rear how much sag you got
on your track?(between track and slides)
ALLSEASONRIDER
I agree with Daman......
Im not too sure last time I checked there was maybe 2 inches?
700triple
Try tighten your track a litte.
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
Check your bearing on the drive axle.
yamaholic22
Sounds like track ratcheting. Tighten up your track and see if it goes away. Make sure you loosen the rear axle when you are tightening the track adjustors, and retighten the axle when finished. If the ratcheting still doesn't go away, take a picture of your track drivers and post it up.
Like others said tighten track some,check for sure on how much you havezacksrx said:Im not too sure last time I checked there was maybe 2 inches?
then try 1" of sag,etc...
