Are specifications listed on this site for rebuilding my 03 Viper motor? Any special things I should be watching out for? I have done a few jet ski motors in the past but never a Viper motor.
*I know about priming the oil pump
*Went through the carbs they were clean
*Cases are clean and ready to go
*Reeds have been cleaned and inspected
*Crank need a few new bearings $600 och
*Needed one cylinder honed all 3
*Going to run SLP pistons
*Pulled gas tank and drained/cleaned
*Cleaned up clutches
*Inspected wiring harness and heat taped hood section due to tipples.
Give me your advise to make me successful I only want to do this once. Thanks Dennis
What to specifically need to know?,,if you've done a PWC before it's about
the same concept..
the same concept..
Case torque spec's and head bolt spec's. Any special things to watch out for?
If your going to tear it down do crank seals and water pump seals,check out your water pump shaft/impeller good,had post's in the past of impeller spinning on shaft when warm, try a search also,lots of info on viper's here..
oh and give me your email,i'll send ya them specs,save me from typing them..
Thank you daman my email:
Dennis.Lynton@Sun.Com
Yes motor is torn down 100% plan to do seals, gaskets and everything that comes in a complete gasket kit. I now have 2 sets of cases my original set has a crack so I am using set #2. Might weld up my cases so I have a lower end motor ready. I think I will stick with this Viper for a few more years. Make me smart please and thank you for sending me the specifications. I should begin building the motor this Wednesday evening the 20th.
