the tree man
Snowmobile + tamarac = I need a trailing arm!What models interchange with my 2000 sxr?Thanks.
JohnnyQuest
I believe any trailing arm is interchangeable in a proaction. With the exception to the viper, they're different
srxeater
correct- vipers use a taller spindle with more caster. all others (v-max,sxr,srx) are the sameJohnnyQuest said:I believe any trailing arm is interchangeable in a proaction. With the exception to the viper, they're different
They are not all the same, you will need one from a long travel sled marked with the letter 'R' on it.
Some other differences also are,some vm's have short spindle's vs tall, srx's had short,sx,sxr's depending on the year had sort vs long,,,etc,etc...
you have short spindle's on yours so if you want to keep the same ride
height with your stock ski's you'll need to find a short spindle T/A..
racerdan
Would there be any benefit from swaping in a set of viper trailing arms on a SXR or SRX? (with correct hardware). Aren't the viper front suspensions suppose to handle better?
