u guys want to get ride of piston problems u have to remove friction which causes heat then u need to put something on those pistons so they can take the heat and the only answer to that is swan tec ur pistons and heads swan tec means teflon coated, this elminates cold seizures which is a problem when u are making short runs wothrotle on a cold engine as cold engines make the most horse power, and this is not expensive just my 2 cents Al Larson
