Are these stock on an 01 SRX or where can I get a set?
YAMMIEGOD3:16
STOCK WEIGHTS ON 00-01-02 SRX. 3:16 (yammie tony)
^^ what he said...
either look/post in the wanted section or your dealer..
Since my sled is stock, I'm guessing I'm all set.
Thanks guys.
Thanks guys.
Yep if she's stock and a 2001 you have them in..
YAMMIEGOD3:16
YOU WILL NEED TO REMOVE INNER RIVET IF YOUR GONNA INSTALL HOT 8DN-20 SET-UP AND ADD 4.5. 3:16 (yammie tony)
Rambunctious
I think the tip already has 4.5
the heel needs to go from 3.whatever to 4.5
for bottom end accelleration improvement ( faster shifting)
that's the ticket
that's the ticket
YAMMIEGOD3:16
CORRECT ON TIP RAMBUNCTIOUS. ( me bad) 3:16 (yammie tony)
Rambunctious said:I think the tip already has 4.5
that's the ticket![]()
Glad to know that rambunctious. I'm not real clutch savy and could have drilled out the stock 4.5's not even knowing it only to replace them with the same.
YAMMIEGOD3:16
VERY SORRY I POSTED WRONG LOCATION. 3:16 (yammie tony)
