srx 8dn-20's
YOU WILL NEED TO REMOVE INNER RIVET IF YOUR GONNA INSTALL HOT 8DN-20 SET-UP AND ADD 4.5. 3:16 (yammie tony)
I think the tip already has 4.5
the heel needs to go from 3.whatever to 4.5
for bottom end accelleration improvement ( faster shifting)
that's the ticket :)
Glad to know that rambunctious. I'm not real clutch savy and could have drilled out the stock 4.5's not even knowing it only to replace them with the same.
