dtd_93
ok here's my deal i wanna know if ya can over load the weights in a clutch... i make my own pins for the weights. and well my last set of pins are up around 10grms... i gram weigh each weight to make sure all is equal... but was just wondering if i could be over stressing things in there....
RIVERRUNNER
Do you mean 10 grams for 1 pin???But if each one weights 5 grams I wouldnt worry about it. But I also wouldn't be putting 7 or 8 grams in each hole!!!!
dtd_93
yeah 10 gram pins
dtd_93
k so i am getting no respones so is that a yes or no??
Weatherbyman
weights
If the motor can pull them you're fine.
i'm sure something will stress after a certain amount of gramm
RIVERRUNNER
What weights do you run that you would want 10g pins??
dtd_93
i got 8dn-20 and was tryin to get outta buyin a new spring... but can kill the motor with weight...
dtd_93
and if i got an over rev will a softer or harder spring load the motor more?
RIVERRUNNER
I softer spring will load the motor....what are you running for a setup and what sled are you clutching?? But you need to post what your rpms are and engagement, and when you pin it, and when you are at wot. What springs, what helix, and what weights you got in there now!!!
Weatherbyman
weights
The primary spring resists or opposes the force generated by the fly weights. A softer spring requires less force to compress. More force is available to grip the belt. This loads the motor harder.
dtd_93
thats what i wanted to hear.... was thinking that way but then the brain starts to second guess it;s self.. so to hell with it ask away..
