pablo11059
daman - could you tell me where their supossed to be or higher is richer ? and i would be running a little rich right now yes ?
maim- well i think they are ok as i ran the sled and sprayed carb cleaner around every thing the block the heads the carbs any gasket i saw really and idle never changed ?
stock on the fuel screw's 1 1/8 turns out,the more you turn them out the richer,so yes you have them set richer..pablo11059 said:daman - could you tell me where their supossed to be or higher is richer ? and i would be running a little rich right now yes ?
pablo11059
i was talking about clip height ? is there a screw under the plate on the top of the carb ? i havent opened that part up yet and not sure what to look for ? i did turn the fuel screws on the left outside carb to 1.5 turns ?
did you spray it in behind the clutch and flywheel? that is where the seals are that i am talking about. they usually go bad if a sled sits for awhile.
pablo11059
no i havent sprayed around those seal but will very soon and let you know asap
