well I have different opinion on this one. by letting your straps all the way out you maximize weight transfer, this does lighten your front end, but causes a great deal of trenching on your sled. Your approach angle or angle of attack as your track meets the snow is also going to be steeper thus making it more difficult to get up ontop of the snow when you launch.
This is what i did to try and get the best of both worlds. Upgrade to a 151, ditch the 141, suck my straps all the way in, loosest setting on front shocks (I upgraded to long travel shocks off an SXR), the longer shocks lifted the nose of the sled bout 3", in the skid I dropped the FRA (full rate adjuster) to the bottom (softest setting) and middle preload on the center and rear shock.
Works for me, 6' 200lbs, aggressive riding, mostly hillclimb and powder playin when i can find the fresh stuff.
You need to ride it first, learn what each change to your rear skid will do for you cuz there are lots of options.
