Yamidude59
Well i noticed that the right rear of the seat was a little loose so i opened up the rear seat pocket and tightened the right nut (looking at the sled from the rear) so i tightened it, it DID tighten the board that holds it down to the tunnel, but i noticed the plastic housing which is what that pocket is made out of is crack around where the nut is, so even though i have the nut tight, the pocket compartment is still wiggly somewhat, nothing major, but it might get worse and i was wondering what i can do to fix this.... I'm meticulous with my sled, and want things perfect, this will now eat at me until i find a solution....
Dave M
Super Glue..
Yamidude59
I was thinking of a more permanent fix, is this a common failure point in the seat? do they even make seats for the srx anymore? seat is mint other then that area.....
Yamidude59
i was thinking of making a bracket that goes inside the rear pocket on the bottom that extends to both ends where the bolts are and that should do it....
YAMAHIZAL700
couldnt you use a large washer to hold down firmly on the plastic?
Yamidude59
does this happen alot in the rear of seat? its nothing major.... probably will try the washer thing, see if i can get one big enough that will work....
