Low RPM squeel
Marker
Renfrew Ontario Canada
I heard a squeel coming from the primary clutch/crank area at low RPM's(idling), is it what I think it is??? It went away after I brought the RPM's up...
I dunno, but my venture does the same. It has a new belt, and the sheaves were cleaned.
keeping posted....I am sure someone has an answer. It has to be in the clutches.
to squeal or not to squeal..is that the question????
as long as your clutches are truely lined up and centered.The 3 bolts behind the secondary sheave,has washers that can be added or subtracted for belt rideing hieght.I put a new belt on the X and it squealed to.Took out the washers from behind,but belt dropped a little to low.So I found washers half the thickness and used them.Belt rides up,but not to high that it would cause a squeal.You want to get the belt hieght as high a possible with out squeal.
what blue said.....
check center to center too
Thanks a lot everyone and yes thanks for the pic daman, big big help. Just registered on here toninght and have learned more in one night then I've learned since I bought the sled 2 years ago.
lol...any more Q's just post up,bluemonster1 will help ya with any clutching
problems you may have,he's been through it all.. ;) :mrgreen:
Oh and :wel: to the site!!!!
daman said:
lol yea i figure it's always helpfull to see what people are
talking about. :)
what, telling me to turn thingamajigee "A" 2 turns to the right and the thingamabob "B" all the way to the Port side doesn't do it for you?
LOL
I work in visual best, as do most......:)
edit..
here is the tec FAQ for belt deflection...
http://www.totallyamaha.net/forums/showthread.php?t=32362
Yamidude59 said:
belt shuld be even or just above secondary right?
If this is for your '01 srx spec is 0.5 bellow to 1.5mm above secondary in that area, but try to keep it flush or above the sheave tho,just so it don't squeal..
If you set it to 1.5mm above or close to that and it still squeals your center to center is probably off. It should not squeal when it's set to 1.5mm above.
