Hatch
I put firecat bars on my viper with there warmer elements that wrap all the way to the hook. I can't seem to get them to work. Need them by this weekend. Anybody know the proper way to wire it. Yellow-ground, Blk & green are low and med. So to get high I was told to wire them together, but its not heating up. I hooked the yellows together and ran the blk & green into the yamaha wiring on both sides. Can anyone help me out? Thanks.
Pm Betheviper
He has run cat heaters on a Yami I believe.
Madmatt
Madmatt
Yellow is hot, blk and green are gound for low and medium. If you wire the blk and green both to ground, it will be like on hi. You variable adjuster works with these. i have m series bars on my warrior, and wired this way they get Hot. So you need to hook both yellows to the power side coming up your stem, and then hook both blk and greens into the ground coming up the stem. it will work. Maxdlx
Hatch
Maxdlx sent you a pm
returned it, you will like them. Paul
