2strokinit
What is the tap needed for a grease cert? I am adding them to my srx so I dont have to change the bearings at 2000 miles.
2strokinit
Btw
Its 1/4-28.
Its 1/4-28.
2strokinit
iTS DONE!!
I have added 3 grease certs. One is underneath the brake assembly on backside of chaincase, another is located at the bottom bearing and the last is on the speedo side. Now I can grease them whenever I want too...weeeee....
no pics or procedure to help other's out???
JENSEN
I would love to see pics of this too.
2strokinit
Ill take some pics
Ill take some of the mod.
Roost 'Er
Are you running a open bearing though? when i changed mine when i did the track swap it was a sealed NTN, so grease zert realitically will only put more preassure on the outter seals of the NTN.....?
2strokinit
Bearing
Your talking about the bearing on the speedo side. I pulled the seal off the the side that faces the speedo side, and installed the cert on the same side. This worked great!! I got some pics of them installed Ill post in couple of days.
2strokinit
Pics
Stupid pics are to big GREAT. Will need some more time here.
Dave M
Why did you not do the one for the secondary clutch ??? it's basically the same as the speedo bearing but under alot more pressure.
2strokinit
Did
I did the secondary at the chaincase as for the bearing directly behind the secondary the design of the carrier made it impossible, it was open on both side....Im sure I could have made something but I need it for a couple more trips. Perhaps when the season is truly over I will address this.
2strokinit
Pics
Here are them pics the one behind the case is hard to see though.
http://www.myspace.com/keepurpinned
