2strokinit
MI
What is the tap needed for a grease cert? I am adding them to my srx so I dont have to change the bearings at 2000 miles.
iTS DONE!!
I have added 3 grease certs. One is underneath the brake assembly on backside of chaincase, another is located at the bottom bearing and the last is on the speedo side. Now I can grease them whenever I want too...weeeee....
Are you running a open bearing though? when i changed mine when i did the track swap it was a sealed NTN, so grease zert realitically will only put more preassure on the outter seals of the NTN.....?
Bearing
Your talking about the bearing on the speedo side. I pulled the seal off the the side that faces the speedo side, and installed the cert on the same side. This worked great!! I got some pics of them installed Ill post in couple of days.
Why did you not do the one for the secondary clutch ??? it's basically the same as the speedo bearing but under alot more pressure.
Did
I did the secondary at the chaincase as for the bearing directly behind the secondary the design of the carrier made it impossible, it was open on both side....Im sure I could have made something but I need it for a couple more trips. Perhaps when the season is truly over I will address this.
