fleet man
Driver Placement on shaft (update)
Can I use the specs for a 01 MM700 driver placement to setup my 97 SX700 8 tooth drivers?
Dimensions
I can't find the SX700 specs anywhere. My manual isn't here yet. Also the PO has the 9 tooth dimensions all
up.
Dimensions
up.
should be the same if using oem drivers. extroverts will have a different placement.
fleet man
No extro's. Just replacing 9 tooth with 8 tooth so I can stud the track. They are aftermarket though.
Dave M
Did we not mark or measure the old ones first ???
fleet man
I would have but the drivers on there are not the correct dimensions. The outside drivers were hanging half out of the track because they are missing the locking collars and the track was off center in the tunnel.Dave M said:Did we not mark or measure the old ones first ???![]()
there are some subtle differences between the 97 specs and the 01 specs, perhaps the newer drivers are different widths. i can give you the dimensions for the 97 if you need them.
