Driver Placement on shaft
fleet man
Manawa Wisconsin
Driver Placement on shaft (update)
Can I use the specs for a 01 MM700 driver placement to setup my 97 SX700 8 tooth drivers?
Dimensions
I can't find the SX700 specs anywhere. My manual isn't here yet. Also the PO has the 9 tooth dimensions all #$%&* up.
Dave M said:
Did we not mark or measure the old ones first ??? #$%&*
I would have but the drivers on there are not the correct dimensions. The outside drivers were hanging half out of the track because they are missing the locking collars and the track was off center in the tunnel.
there are some subtle differences between the 97 specs and the 01 specs, perhaps the newer drivers are different widths. i can give you the dimensions for the 97 if you need them.
The dimensions for the SX 700 on that page work perfectly. I went by those and it moves sideways on the track with about an 1/8" of play.
