Styles211
I have a 99 srx, on my last ride it started to bog bad past half throttle. The fuel gage, tac and powervalve servo all stoped working. I have checked all the wiring and have found no problems. All lights are still working and bright. It will run, but as I said bogs out at half throttle. Are all these symptoms of a bad CDI?
Styles
Styles
YAMAHIZAL700
Not sure but If you need one I have a good one for a 99 srx 700.
check wiring again .......and check stator
Styles211
Did the 99's have the wiring harnes problem? (under the motor) I thought it was only the 98's?
Modsrx: I will also test stator..
Styles
Styles
no they all have the wiring problem 98-02
