"srx 800 king of the lake"
there have been about 10 people ask me what pistons i use they are spi artic cat 580 twin pistions with machine work done to them.
amatosrx said:
our 780 have big bore has over 5000 miles on it no problem. he is right the cylinders are small there is not much room for an 800 but 780 works good.
Thanks the kind of reliability im looking for :)
Ever have it dyno'd?
The 800 SRX was the same bottom end, the 74mm bores have thicker aluminum around them as well larger internal transfer castings, the outside looks the same.
What you have to do is bore the cases .125 larger for the wider sleeves and they drop right in. Wher ethey ran out of room was on the top, they have gaskets instead of orings.
