Torque Spec?
Jed Ashby
Canada
(1994 Yamaha V-Max 600)
Good morning everyone,
Just wondering if someone could help me out with the torque spec's for the head bolts(12mm), and the base bolts for the jug's (14mm). Also.....what do you guys think about re-using the head gasket? It looks like its in good shape!
Thanks in advance
Jedrow
'94 v max is...
head bolts--first 14 ft.lbs--final 22 ft. lbs
cyl. nut's--first 14 ft. lbs--final 24 ft. lbs
you could try to re-use the old one if it doesn't leak great,but i would
use new if it were me..
