00' SRX clutching
jaydaniels
Amherst NS
Here is my clutch setup for an 00' SRX I just purchased. All stock other than 23/40 gearing. Any input or opinions will be appreciated. Not sure what to wrap my secondary spring to.
8BU-00 weights with 4.5g in tip
y-w-y primary spring with 2 engagement springs
green yamaha secondary spring
53/47 Helix.
Also, how do you change the bushing in the secondary clutch? The one on the housing not the helix. Just pound it out?
JAY, HERE WHATS IN MY 2002.
8BU-00 WEIGHTS
13.9 INNER
13.3 TIP
WHITE MAXXIMUM SPRING
50-40 HELIX @ 2-6
GREEN SPRING.
SLED IS BRUTALLY FAST. I HAVE HEEL CLICKER SET-UP ON HOLD BECAUSE I LOVE THIS. 3:16 (yammie tony)
Tony,
Do you use that set up for 660 or 1000'? Also, if you do 1000' runs what gears are you using? Thanks
8BU-00 WEIGHTS
13.9 INNER
13.3 TIP
50-40 HELIX @ 2-6
GREEN SPRING.
Thanks. I might play a bit with my clutching.
