grass draggin'
SRXpilot
Berlin Wisconsin
I am thinking about running in grass drags this summer. I was hoping for some carburation and clutching tips. I've never done this before and never tried to run a sled during hot summer temps. Any tips would be greatly appreciated.
What I have:
2000 SRX 700
airbox mod
V-force reeds
Heel Clickers in primary
Bender Roller Rooster on secondary
1" track with 144 studs
pm me, I will give ya a complete set up,clutching,gearing,suspension,jetting.
Any chance i could get that info? Do you know what track options you canuse in stock class,(any aftermarket etc.) thanks!
THANKS! What kind of engagement rpm are you guys getting away with ?(I think years ago 5000 or 5500 was max in stock classes).
There's no engagement rule.
I think almost everyone that ran heel clickers on grass at least i did and know others that did.Notched them for higher engagment.I was engaing my srx at 5400 on grass.
Right where the bend is at ht eheel where the roller sits,take a dremel tool and gring out some evenly so you blend it in to the profile of the weight.
Run lot's of heel weight and tip weight at least i did with great results.I ran 130 mains across the board but elevation and temp has a big play in that.
